fx loop send works, no speaker out sound. I see some carbon burn marks on one of these output chips. There are 2 11-pin output devices in this and they are not labeled in any way. What part # might these be? I figure I'll check the surrounding components and power supplies etc and replace the outputs and should be fine.
Hollinger PA - no sound
Ok this power amp IC looks alot like this one on page 4 of the link below - labeled DBS.P. However the one in this PA is an 11-pin. Any ideas anyone?
http://ics.nxp.com/packaging/handboo...kgchapter1.pdf
I thought I responded last night, but I guess not. Look up the data sheet for the common LM3886. it has 11 legs. DO the connections make sense for your amp?Education is what you're left with after you have forgotten what you have learned.
