I picked up a point-to-point tube amp as a project. The amp (supposedly) has iron from a Hammond organ, 5Y3 rectifier, 2 x 6V6, 3 X 12AX7''s on a homemade chassis. It works, doesn't have a lot of clean headroom and sounds pretty "brittle" but should at least be a backbone for playing around. My biggest concern is that all the components are just soldered together and flown above the chassis. This doesn't seem very robust to me--should I put a tag board in? I don't see any kind of bias circuit (I haven't looked really hard yet.)
The amp is laid out on a sort of 5E3 design where the chassis sits vertically in the cabinet with the tubes on the rear. I'm wondering if I can just get a schematic for something with a similar tube complement and rebuild this to suit my needs. Any thoughts? One more question: The OT is wired for 8 ohms now. There is another pair of leads cut off; I'm wondering if these might be 4 ohm leads. How do I test this?
