Long time lurker, first time poster. I'm the proud owner of one of those Chinese Crate amps with the SMPS that likes to die (100 watt head). I humbly bow before you to ask for suggestions...on where to proceed; I realize the best suggestion may be to bash it mercilessly Office Space style.
A little background:
I'm very new to tearing apart amplifiers, and electronics in general, but I'm a good student. If fact, I bought this piece of machinery to teach myself how to do this stuff, only paid forty bucks for it too. I had no idea what a switching power supply was when I bought it, and given the complexity thus far, I would have bypassed it had I known. The kid said he took it to a tech, and it needed fuses and new power tubes. Wrong. I tested the fuses as soon as I got it home, they were fine. I should have known then that I was in for the long haul, but I proceeded to track down schematics, test components on the main board, and generally struggle, although I learned quite a bit in the process. Essentially, the thing powered up and lit all the tubes, but wouldn't make a sound, not even a hiss. After a couple of months, I decided that I was beyond my skill level and took it to a local tech. $80 and a couple transistors and a flameproof resistor later, I had an amp that still didn't make a sound. The tech wasn't sure what was going on, and I decided I would take another stab at fixing this thing myself, having done some more research.
So, I've had the amp for a few more months since then, and I've fiddled with it, cursed at it and threatened it, and finally I discovered that the SMPS is not putting out the correct voltages. In fact, there is almost no B+ voltage, and the other voltages are out of wack too, though not by nearly as much. Why the tech didn't realize this, or bother to tell me, I'm not sure. The way I figure it, no B+ means no sound, and the other voltages are close enough to their specifications that nothing is exploding and all the tubes are lighting up. I surmise that one of the power tubes shorted, sending power where it shouldn't; there was a fried resistor on the main board, and two fried transistors on the power supply that the tech replaced.
After reading multiple sites and pdf's about troubleshooting SMPS's, I'm inclined to believe that one of the electrolytics is faulty, either in one of the outputs or the feedback, causing problems to the reference voltage or excessive ripple. I'm fairly limited in equipment (and skills, haha); I tested all the components on the board using my DMM with whatever tests I could find on the 'net, but I don't have an oscilloscope or an ESR meter to test capacitors. I did test that the capacitors would charge (measuring resistance to infinity), but I've read that it is really only good to tell you whether the capacitor is totally open or shorted, not whether it is functioning properly under powered conditions. Obviously, there are no bulging caps anywhere.
So, at this point, I'm looking for suggestions as to what steps to take next. I intend to purchase an oscilloscope, but that will be many months away, and I still have to learn to use one. Most folks recommend replacing all the electrolytics, given that they are cheap, is that a reasonable next step? And should I replace the big filtering caps on the primary side as well? I'm open to any advice you might be willing to give.
I realize I'm a noob, so apologies if I've committed a sin against tech law. Thanks in advance.
