hey there i have a sunn concert bass (silver) and black version, early 70's that is having some problems with the negative voltage rail. when i got the amp it was having some hissiness from the output. it turned out to be two faulty bc107's in the preamp. while i was in there i was taking some measurement just to make sure everything was solid in the supply and i accidentally shorted a negative side of cap to ground on the preamp board,, the positive side on this cap goes to ground. looking at the schematic below it was C128 at the 45 test point. this test point has a wire that goes to the power amp board and connects to test point 29. from there it travels back goes north and hits a 330 ohm resistor R319 and then through CR306 then to ground. first id like to say that R319 is missing from my amp, there is just a jumper in mine. as a result of this mistake i shorted out the diode.
no big deal, i just replaced CR309 with another. also, from point 29 it travels east to two more resistors and a recitifier. i noticed that R320 and R321 in mine are both 1k and NOT 5.6k and 470 ohm respectively like stated on the schematic. i left those alone because they looked stock and went ahead and brought up the power on the variac. now, i am getting -32 volts on point 45 and not -15 which it is technically supposed to have. i never checked this voltage before but being the cap i shorted was only rated at 25vdc i assume this voltage was never supposed to be this high.
now the preamp board is getting this -32 vdc and the fet's (Q101,Q102,Q103)where TEST POINT 45 leads to via 18k resistors are not getting any voltage on the other end of the 18k'S, how could there be -32 vdc on point 45 and on the other side of the 18k's none?. so basically what is happened is, if i run a signal through the input jack, it initially works and then the signal just fades away as if the transistors are completely saturated, but they are actually not receiving any voltage???. I unhooked the jumper from the power amp board to see if the -32 voltage would change and it remains the same. i checked the rectifiers on both sides and they seem to be ok. the power amp in on back works fine. any help would be great. ENZO? haha...thanks!
EDIT: MOVED TO troubleshooting section!!!! sorry!
http://sunn.ampage.org/site/schematics/concertbass.gif
