Here's what came in...Heavy road use (worldwide) Acoustic head, power xformer, one screw holding it on, scraped chassis causing metal shavings all over output jacks. All Eq sliders road damaged. Blows internal 7A fuses. What I did: cleaned & wash chassis, remount xformer, heat shrink over xanny wires that were scraped. Check xanny insulation w/meg meter...seems ok (500M+) pri/sec/core. Replace all sliders. Check bridge, caps etc. Variac up, inject signal. Have signal on scope. Vcc 98Vdc, at OT cap 50Vdc, 0 Vdc on scope. Ran for about 1 minute. Heard a small arcing sound, small bang/click sound (like a big relay clicking in), fuse blew. Quick check output xsistors, seem ok, replace speaker jacks. (metal debris?) V up again, voltage at OT cap about half Vcc, lees than a min. bang...Disconnect Vcc from OT board. Power up, check signal at Pre out..ok all controls function. No fuse pulled. Measure about .120A AC at internal fuse link. Took out power PCB, removed & check all driver xsistors (all OK), replaced all E caps on board, redo solder joints etc. Took out all but one known good pair of RCA480060 power xsistors. Power up, no signal, loud bang at 110VAC current read before failure .150A ac. Rechecked all work. OT xsistors still ok. Note: the sound seems to be coming from inside power xformer? Could it be arcing from more current drawn from output PCB? I never encountered such a thing. Any help is appreciated. And of course, the band needed it weeks ago...
Also could use a READABLE schematics. Thanks guys!
