I think I posted this in the wrong place originally, sorry about that im new here.
I have 2 silverface champs, one sounds very good and the other still sounds good but is more shrill sounding. The voltages vary a bit between the two amps. Could this amount of voltage variation cause that much difference in sound? If so how could I get more voltage out of the other Champ?
The caps are all original in both amps, they both have the same brand of tubes (I swapped them back and forth to see if it made a difference any way) they both have weber sig. alnico speakers (I tried swapping them as well)
here are my voltages
the good champ.
12ax7 6v6 5y3
pin. VDC pin VDC pin VDC
1 256 1 0 1 1
2 0 2 0 2 424
3 2 3 410 3 0
4 0 4 419 4 -6
5 261 5 0 5 0
6 0 6 0 6 -6
7 2 7 0 7 0
8 0 8 24 8 424
here is the cap can voltages I tried to make it how the can looks facing it
-- = 423
l = 413
-- = 391
the bad champ
12ax7 6v6 5y3
1 255 1 0 1 0
2 0 2 0 2 399
3 2 3 386 3 0
4 0 4 395 4 -6
5 247 5 0 5 0
6 0 6 0 6 -5
7 2 7 0 7 0
8 0 8 23 8 399
cap can
-- = 400
l = 395
-- = 371
I just found this forum tonight and Im very happy to be a member. The tube chart will be very helpful in the future. I still pretty new to tube amps so go easy one me guys
the good champ.
12ax7 6v6 5y3
1 256 1 0 1 1
2 0 2 0 2 424
3 2 3 410 3 0
4 0 4 419 4 -6
5 261 5 0 5 0
6 0 6 0 6 -6
7 2 7 0 7 0
8 0 8 24 8 424
-- = 423
l = 413
-- = 391
the bad champ
12ax7 6v6 5y3
1 255 1 0 1 0
2 0 2 0 2 399
3 2 3 386 3 0
4 0 4 395 4 -6
5 247 5 0 5 0
6 0 6 0 6 -5
7 2 7 0 7 0
8 0 8 23 8 399
cap can
-- = 400
l = 395
-- = 371
