I know it's normal to hear a littlehum in the reverb circuit when the reverb is turned up, but this is an annoyingly loud hum even with the reverb turned down.
The amps been re-capped (electrolytics) and otherwise sounds great.
It has the waxed fiber boards and brown coupling caps. The reverb reads normal dc resistance (about an ohm and 180+ ohms) I've tried several tube swaps. Possible WTF syndrome? The amp was worked on before (clean work), and I had to perform a bit of de-mod work.
This is a several hundred dollar repair, and its a bit dissapointing to have an "unfixable" problem!
Any help greatly appreciated!
