Hello,
my new 5F1 build is in the thorough testing phase, and after fixing the hum and most of the rattling at high volume (as much as the rectifier tube du jour will allow it), I've found this issue: when I turn the volume all the way up (12/12) and up the volume on my guitar (P90 pickup/bridge) to about 70-100%, I eventually get this fizzing sound accompanying the notes.
I assume that what's happening here is what's usually known as "blocking distortion", a power tube problem. My build is pretty straightfoward, if you take the Weber layout ( http://taweber.powweb.com/store/5f1_layout.jpg ) the only difference in my build is that I'm using a 470R/3W metal oxide screen grid resistor, and a 1K5/0.5W carbon composition grid stopper resistor on the 6V6GT output tube.
I'm assuming I need to up the value of the grid stopper to eliminate this problem?
I'm attaching an MP3 I recorded of the problem. Is this what blocking distortion is supposed to sound like in a 5F1: fizz.mp3 ?
