MF350 issues (yes i searched)
  • MF350 issues (yes i searched)
    So i picked up a MF350 (mode four) for a few buck that was blowing fuses. One on the power amp IC's is totally shot, so i unplugged all four of them.
    Fuses no longer blow, but i recall that i should be able to hook up an amp or headphones to the emulated line out and hear something that resembles a guitar(if the said guitar is plugged in, etc.)
    so here is what happens. When i turn the unit on, power switch lights. fans run, but the tubes do not heat up nor do any other lights (channel select etc) on the front light up. i also get no sound out of the previously mentioned port in the back.
    Is there something i am missing? Has anyone else had this problem?
    Thanks,
    -Dustin-
    As on any amp, if you are missing a variety of functions, start with power supply.
