So as the title says my Ashdown Five-Fifteen 15" 100w combo amp blows it's fuse immediately after being turned on. The amp is solid state, so I can't do my usual and blame it on the tubes
I should mention here that by fuse I mean all 3 fuses; the main fuse and the 2 internal PCB-mounted fuses.
Unfortunately I realize this symptom could mean almost literally anything at this point, so I need some help narrowing down and getting to the bottom of this. I would like at some point to be able to use this amp again instead of just having it as a fuzzy nightstand
Everyone's help is greatly appreciated. This forum has helped me fix an amp before, the know-how is definitely floating around here, I just need some help.
Thanks!
Thanks!
