Has anyone seen/did/heard of modding a jcm 800 (50 Watt) for chan switching? I have one that was modded using a 6 contact (3 n.o & 3 n.c.) 24 vac Potter & Brumfield relay. The relay coil circuit includes a 120/24 vac transformer, 2 lights (normal on and switched on), and a footswitch jack. It uses 2 of it's own contacts (n.o. & n.c.) to power the lights. This all works. The other contacts are used to switch in a 2nd pre-amp and master vol pot. The 2nd master vol works as well. It's the 2nd pre-amp vol that seems to be the problem which is low note buzz and sometimes a high freq sound not unlike tuning in a ham radio... I had to draw the circuit myself (no known history).
Question is: has this been done successfully before and is there something I can compare it to? Thanks in advance for any info...
