Need help identifying this amp
  • Need help identifying this amp
    I just bought a amp which i bought doa for nearly nothing. anyway im trying to find the schematic for it. i went to scematic heaven and believe it to be the classic b schematic under the peavey section but that schematic shows 2 6l6c and the owners manual says 6l6gc dont know if theres much of a difference but the (g) means something.
    I believe it to be a 1974 50w combo. your help would be appreiciated
    below I included some photos to help
    Thx
    It is a Peavey "Classic" and would be the A series. There are four input jacks, two bright and two normal. That is the A series. A B series Classic has four jacks, but they are one each bright, normal, series, parallel. Not what you have.
    Your amp uses two 6L6 power tubes. The B series schematic at SChematic Heaven is not for your amp, but if you look, it does say 6L6GC for the power tubes, not 6L6C.
    ANY 6L6 currently on the market is perfectly fine for your amp.
    Historical note: the original 6L6 tube was a metal tube. You can find these here and there today. They are NOT suited to guitar amps and have much lower ratings than modern tubes. But that is plain 6L6. A long time ago they made the glass version of the tube and it was the 6L6G - G for glass. Later, improved versions came out, the 6L6GA, the 6L6GB, and finally the 6L6GC. Good luck finding a 6L6GA. You probably can find NOS 6L6GBs out there, but don;t waste your time and money on them for this amp. 6L6GCs are made today. You can also find things labelled 6L6GB on todays market, but they are really not "real" GBs, and they would work fine too.
    You want some letters? I think the Ruby Tube 6L6GCMSTR is a real nice solid tube that is happy in this amp. But the common SOvtek 6L6 family of tubes would be fine, or any one of a number of current brands.
    Customer service at Peavey will send the schematic upon request. But here it is.
      I'm no Peavey historian but it looks like a early Peavey Classic with a makeover !
      http://www.peavey.com/assets/literat...ls/classic.pdf
      EDIT : just read Enzo's post and the above manual and attached picture
      is for the "B series Classic has four jacks, but they are one each bright, normal, series, parallel. Not what you have."
      Thats the user manual.. probably preceeded the VTX ones and after the Mace/Deuce ones.
      You are the best one to tell which schematic matches by checking the components
      against the drawing but I think you are right with the 74 model.
      Regarding the tube suffix this could open a can of worms although a pinned reference
      on this site that could be added to would be a good idea as it often comes up.
      I thought GC meant Glass Capsule but therer are variations on it .
      It appears originally it was a 6L6G went through some revisions and became the 6L6GC.
      In your case it depended who wrote the schematic and what 6L6 was around at that time.
      See these links for more confusion !
      6L6 STR - GC etc. What's the difference ?
      6L6 STR - GC etc. What's the difference ? [Archive] - Telecaster Guitar Forum
      Tube Designations
      Tube Information
      Valve Type Numbers
      UK Vintage Radio Repair and Restoration - Valve Type Numbers
      This excerp from Tremo (October 22nd, 2005, 04:26 PM) on the Tdpri site is excellent !
      The alphabet soup of prefixes and suffixes you find in current manufacture tubes are mostly for marketing hype purposes, and have little bearing on what it all meant back in the old days.
      All this applies to the large octal base tubes. When 6L6s and 6V6s first came out, they were in a metal envelope. When the first glass envelope versions were introduced, they had a G suffix applied (6V6G, 6L6G). These first glass versions used the large bulbous shouldered envelopes. Then they went to the smaller tubular straight sided glass bulb, a T suffix was added, hence the 6V6GT (glass, tubular). A later beefed up version came out, which was called the A revision, hence the 6V6GTA
      With the 6L6, they additionally did some internal mods to the guts to increase it's power handling, so the newly revised design became the A revision, so we had the 6L6GA. More revisions and beef-ups followed, giving us the 6L6GB and ultimately the 6L6GC.
      STR, depending on who you talk to, stands for "special tube request" or "special test request". Basically what this meant back in the day, is a large OEM customer would request the tube factory to test or tweak an current production tube for a specific operating condition or parameter. Like operating base-up in a high vibration environment, for example. Today, it's just more Mesa BS marketing. Mesa does not make tubes, they just buy them from the usual suspects and put their own labels and nomenclature on them. Mesa resells a couple three different versions of the current production 6L6, so they need a way to differentiate them from one another.
      Looks like you have a bargin there ..and plenty of room for modifing if thats your thing !
      Last edited by oc disorder; 07-13-2010, 08:06 AM. Reason: 'cause I can and incorrect info
        thx guys thats a start. I dont know much about fixin amps and thats why I bought one for cheap that doesnt work. all I currently know (punn intended) is that the caps could hold energy and not to electricute myself. hopefully with some help I can bring it back to life.
          The user manual I posted above was the wrong one.
          ( well I did say I'm no Peavey historian ! )
          There are some rather high voltages in there and in the transistorised preamp.
          For starters with nothing on or plugged in check the 5w Ik square ceramic (cerment looking)
          resistor in the power supply.
          As these have no (standby circuit) HT high voltage fuse a short in the output tubes could
          make the 1k go open circuit.
          Also check there is bias (with amp in standby tubes removed) approx -50 volts on both pin 5's .
          Multimeter on DC range negative probe on metal chassis positive probe on pin 5.
          Be very careful and tell someone what you're up to ..to play safe !
          That's two main things should be checked before plugging in new tubes.
            Aspen Pittman has been spreading the baloney that GC means "glass container." Well that would be fine until we consider GB. I suppose we could assume that meant "glass bottle." But then what about GA? Um... "glass, ah,I don;t know what" Or maybe "glass around the rest."
              theclassic.pdf
              Is it a "THE Classic" ?
                To be picky, I'd say no. I think they are saying that the Peavey Classic is "the Classic." Not that the model name has the THE in it. Their Classic is classic, so to speak.
                  Ah, as in "you shall have no other classics before me!"
                    You didn't, by any chance, pick this up off of ebay a while back? I bid (unsuccessfully) on one that was also billed as "for repair". Seller was Los Angeles area. It looks really clean. Can't be too far gone wrong. Doesn't look like anybody dropped it off a truck or anything.
                      actually I did and possibly outbid you. My thought process was simple. I wanted to build a tube amp to learn about how to fix them. problem is the cheapest I could find was $245 or so on ax84 and it was a 15w. i thought abought and came up with the idea to find a broken one. Since all my parts are there except for the broken part (parts) I was willing to go up to $200 including shipping so I placed a max bid of $165 (35 shipping) and outbid the last at $145. Recieved it 2 days ago and it is as discribed. Turns on but nothing on the output speakers. gonna start to take her apart after I practice for 45 mins. One thing I did notice when bringing it in was that i could hear the reverb spring bouncing on the chassis. could be broke. not sure if this would stop it from producing sound or not but maybe.
                        Reverb springs normally make racket bouncing around in the tank. Nothing to worry about.....
                          I think you probably did outbid me. Sounds like you met your budget, though, so Good job! It would certainly fetch more if it worked, and I'm betting you won't have much into it when you get it running.
                          Are you planning to just fix as-is, or did you have an idea to implement your own circuit? Strictly speaking, repairing an amp is not the same as building one, and this is hyrbid, part SS part tube.
                            First I would like to get it going see how it sounds. if its not what im looking for then a mod would be in order. I happen to have another peavey 1984 roadmaster sporting 12 tubes and the thing sounds good not to mention its extremely loud 160w head. always like my marshall but Im not a stckler for names just what sounds good for whatever im trying to play.
                            Anyway its open I havent tried any tests yet will do tommorrow but it is strange that all that sound comes out of something that looks ridicously simple. Ive included more photos. Not only am I enjoying the challenge Im meeting a bunch of guys who seem down to earth. Rock on
                              I better go get some dinner, my blood sugar must be low or something. I found myself looking at the screen thinking, "hmmm, that tablecloth would look good as tolex or maybe grille cloth."
