Thought maybe one of you pros could help me figure out my issue
AMP: 1997 Fender Hot Rod Deville 410
Issue:
At first I noticed my sound would just cut out.. and back in randomly. It could happen 30 times in a minute, or once in a week. It was completely random. When the issue occured and not immediatly correct itself, I would jiggle the jack going into the amp. This easily fixed the problem. As time went on I would find it more difficult for it to produce sound by jiggling the jack. As of the past 6 months or so, it is almost impossible to fix the cut outs. When it cuts out you can barely hear the sound coming out the speaker, it is there however. The sound also sounds like it is static as it goes from regular to cuting out. Sometimes it is also accompanied by a pop with an echo.
What I have done:
1. I have tried different cables
2. I have tried both inputs on the amp
3. I have tried the overdrive channel, bright button an any other combination of settings on the amp to figure this out.
4. Tubes have not been changed.
5. I have done the jack replacement on input 1 and 2 to metal input jacks thinking that this is the most common issue with this amp. I made 100% my solder points were perfect, closed it up and hooked up the power and my guitar. It seemed like for about 30 seconds it was working fine. Then the cut outs started again. What is weird about this time is, (and this could have been the case before I just never noticed) if I strum the strings HARD.. the amp seems to play.... LOUD.. which is good. But if I lightly strum or pick, the amp cuts out again. So I'm not sure if I was dealing with a jack issue PLUS some other issue, or if there were never issues with the jacks to begin with.
From all the reading about tubes I didn't think changing the tubes would be the issue. Unfortunately in the past 7 years or so I haven't played much so the tubes really aren't being beat up all the time. But the amp IS from 1997.
Now I am stuck.. so what do you think? Am I just going to have to give it over to a repair shop and pay anywhere between 25-50% of the worth of my amp?
Issue:
What I have done:
