If it didn't fix the problem, what is still wrong? Or are you referring to the preamp issue?
If the power amp still has a problem, earlier you said you were shorting out resistors or some such. That leads me to want to check for any damaged ones from that process. The phase inverter is right there. Check the DC voltages around that.
Plug your guitar into the FX return jack to test the power amp alone.
