Hi all,
I just built a homebrew Gibson Scout-based amp with 2 x 6V6, 2 x 12AX7 and 1 x 12DW7 for reverb. I got her working for all of 10 minutes before the trouble started.
Now the reverb was the biggest problem at first but some online forumites helped me and I got it working fine for 10 minutes before the kids had to go to bed. The next day, nothing! There was a ticking sound in the tremolo which I was advised to change 2 resistor values and again nothing last night.
I'm still a novice having built 5 amps, 2 from scratch but troubleshooting is an issue for me. I usually have to bring an amp in to a tech when there's a problem, but I really want to progress past this kind of thing. Thanks if you can help!
Here's the problem:
When I turn the amp on, the pilot light does not always turn on. The standby switch
has to be flipped and usually it's ok (but not always).
Then, when the amp warms up, I do not always get sound. If I do not, I turn the amp off and there is a loud electronic "swooshing" sound that comes form the speaker, like a capacitor is discharging or something.
Last night I DID get sound (amp hissing noise), but I lost it as soon as I plugged the guitar cable in to the input jack. Weird.
Lastly, the reverb only worked briefly. It is in parallel with the 2 gain stages, so it adds noise/volume as I turn up the reverb knob even if there is no reverb coming through.
I am normally quite good at soldering and every connection looks fine. Of course I did not base this build on a schematic, but rather gut shots of a well-known amp. I literally copied component values where visible and for the rest, good educated guesses along with tips form online gurus (?) who helped.
Please advise where to start troubleshooting! I have no oscilloscope, just your standard multimeter.
Here's the problem:
