Just picked this amp up--it sounds great but the reverb is out and I'm hoping that between the ptp wiring, the included schematic and a little forum help i can fix it on my own.
From what I can tell, the reverb recovery side of the pan is fine. With the amp on, shaking the pan results in the usual clanging about that one would expect. This makes me assume it's a problem in the drive side. The reverb is driven by an EL 84. The previous owner had a 12ax7 in the EL 84 socket, so i swapped it for the correct tube, but still nothing. So, where do i go from there? Any obvious internal failures that would result from a 12ax7 being plugged into an EL 84 socket? Is it time for me to start checking every component around the reverb drive?
THANKS.
THANKS.
