I just picked up a Classic VTX very very cheaply, owner said it had a "hum". It does indeed have a minor hum which comes and goes, 120 Hz. Bass notes are extremely distorted, some distortion on higher notes.
I'm getting B+ at 326 VDC where it should be about 525 (yes I'm on High power, low power it is less than 200), even without the tubes in. The PT is reading 185-0-185 on the HV AC. The PT is the correct Peavey part number (it's actually the same PT that's in the Triumph 60). The two 100 mfd main caps show no sign of discomfort or bulging, and they are not getting warm to the touch. Both plate readings were about the same, so I'm not inclined to believe there's a problem with the OT drawing excessive current. (The low voltage to the preamp is OK, 26-0-26 before the zeners)
Conceptually I'm, wondering WTF is dropping 200 volts off the B+ regardless of whether the tubes are in or out. I have not had time to put a scope on the power supply yet...just curious if somebody has messed with Peavey's high/low power supply enough to offer a quick explanation...
