Hello, new to the forums I dont know very much about tube amps, this is my first tube amp. Marshall jcm 2000 dsl 401 combo amp. A week ago the volume faded out and a few seconds later it came back, now the volume is gone. it powers up but when i switch on the standby nothing happens. the only thing ive noticed is when I look in the back the 4 slim tubes ( im guessing those are the power tubes) have an oragne glow at the base, the 4 smaller wide tubes arent lit up at all. Ive been searching the web for days trying to figure out what that means.. do I just need 4 new pre amp tubes? or was a fuse blown? I dont even know how to check the fuse or what kind of pre amp tubes this amp takes. A good starting point appears to be checking the fuses, I just cant find any instructions on where to find the fuses to check, any help would be appretiated. I typed this quick so please excuse spelling, thanks
Marshall Jcm 2000 volume fade out!
Hi, I have a JCM 2000 DSL 401 that has a similar concern. It will fade out just like you turned on the standby and a few seconds later it will fade back in. This will happen 3~4 times and then the volumn will not come back. Turn it off, let it cool, and the process starts over...
Any ideas?
Byron LordByron444@gmail.com
Originally posted by Byron View PostHi, I have a JCM 2000 DSL 401 that has a similar concern. It will fade out just like you turned on the standby and a few seconds later it will fade back in. This will happen 3~4 times and then the volumn will not come back. Turn it off, let it cool, and the process starts over...
Any ideas?
