Hi there. I have a Fender Frontman 212R that was humming when nothing was plugged into either input or the power amp in (FX return). Otherwise, it worked fine and the guitar signal was as it should be. Here's a schematic for reference:
Google Docs
While I was testing transistors in the 'Mute' section (Q6,7,8), I accidentally shorted the legs of either Q8 or Q10 (next to each other). It was only momentary, but now the amp hums all the time and the guitar sounds fizzy and distorted through the output. I tried replacing all of Q8-Q13 as a shotgun approach, but no luck. Since the hum is really loud through the 2x12" speakers (4 ohm total), I connected a 10ohm dummy load while testing voltages. However, the dummy load gets very hot, suggesting to me there's a LOT of current running through it. This same dummy load takes the output of a 100W tube amp without getting warm, so I'm thinking this is abnormal.
By shorting legs of Q8 or Q10, what components could have been fried? I don't have parts for Q14-21 so I'm really hoping it's not in there! The hum seems to be worse after replacing only Q13- the original tested bad for hFe. Perhaps the replacement is incorrect, although I'm using the equivalent, according to NTE (2SC2383>NTE31: http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/).
I'm up sh*t creek with my inexperience with solid state- hoping someone can throw me a paddle!
Thanks,
Jaret
Google Docs
Thanks,
Jaret
