Hey fellas!
Looked through this topic since the same amp with the same problem was covered: http://music-electronics-forum.com/t18559/
Alas, trying everything mentioned didn't help... every semiconductor tests good (except for U2)
So I'm getting a wonderful 40 VDC out to the speaker... which is BAD!
Pulling U2 out of the circuit gets rid of the 40 VDC to the speaker, but only +15 VDC goes to U2 in the schematic... there isn't any 40 VDC that's supposed to go to U2 from what I can see in the schematic.
Also, I've found that turning off the Compressor/Limiter switch kills the 40 VDC.
Here's the catch: I get rid of the 40 VDC going to the speaker, and it gets replaced with 19 VAC... and there's still an annoying hum. I know people have mentioned the two large filter caps, but that was if there was only a hum... not a hum and 40 VDC with it.
It's definitely NOT the preamp; No harsh voltages coming out of it, disconnecting the preamp does not fix the problem, and I can plug the preamp output into another power amp, and everything sounds fine, so that is ruled out.
Any ideas?
THANKS!!!
Any ideas?
THANKS!!!
