Ampeg svtiii pro relay
  • Ampeg svtiii pro relay
    Hi All!! Regardless of which input (front panel or power amp in) I apply signal to, the relay ( next to speaker outputs) trips out every few seconds or so, then kicks back in. With no signal applied the relay does not trip off. The amp sounds fine when the relay kicks back in. Also, lowered level input signal does not trip the relay. The fan slows down a bit when the relay trips but continues to run. Not drawing excessive current at any time. Also the green "on" LED in the graphic EQ section lights when I apply strong input signal (with EQ in off position) and seems to track with the relay tripping on and off. Could the relay be weak?
