Hello all! I've got an Ampeg SVT-II all tube bass amp that has a terribly loud hum at any volume settings. I've done a bit of poking and prodding around and have come up with the following observations:
1) I've found a signal with an odd looking waveform, which seems to correspond with the hum, present on the plate off the first gain stage into the phase splitter, and also on the grid, plate, and cathode of the phase splitter (cumulatively, V1 in the power amp section)
2) When I pull this tube, the hum/signal goes away
3) I've tried replacing, one-by-one, all of the caps around this circuit to no avail, and have measured good resistance values on the resistors as well
Any thoughts, or need for clarification? Thanks!
Best,
Shane
Best,
Shane
