I had a Peavey Mk4 bass head come in with blown outputs and upon first look a bit more extensive damage on the main power board. So to try and save some $$ on parts and having had a few of this era of Peavey heads in before I went through my "collection" and found an XR600B pa head which someone must've given me with power cable cut off that I never fixed. This head seems to have the same power board/output module with just a couple minor differences in cable connections so I just swapped the whole thing into the MK4.
The amp is now working with this board installed but the volume just isn't near as loud as it should be and the tone seems really mid heavy for some reason. So I'm wondering before I go troubleshooting the replacement for problems, Is there any difference between these 400HB boards I should be aware of? any minor tweaks I missed which I should've made before swapping?
I figure it may save me some time as some of you guys are surely well versed in the revisions etc.. of this old standard
NOTE: I did check the OT's in circuit on the replacement board and the high vltg rails are +/- 52v also checked at least one pair preamp rail vltgs good at I think 15.5v +/-
THANKS
THANKS
