Amp powers on. NO sound. Not even hum or hiss. Fuse hasn't blown and power transistor voltages seem fine. I'm suspecting the speaker jack relay. Maybe the relay is not the problem, but is doing its job and shutting off the output. Here's what I've got so far. I'm thinking if all these voltages seem good then maybe the relay IS the issue.
These are DC readings.
TP11: 5mv
TP18: 24v
TP17:6.6v
Q23 Base:.7v
+16v supply on top of R64:OK
D19 across relay coil:OK
+60v on cathode of D19:OK
Relay coil reads to spec: 1.44k
Ampeg B2-R.pdf
TP11: 5mv
TP18: 24v
TP17:6.6v
Q23 Base:.7v
Ampeg B2-R.pdf
