Hi guys, I have this BA115hp that came in blowning fuses. Ofcourse all the mosfets were toast, so I replaced them along with the drivers, Q3 bias tranny, D8 and D9 zeners, D6 and D7 diodes for good measure. I started her up on the light bulb limiter, then it which went way bright, so I aborted and removed the power mosfets & started up again to check the rail voltages.
I discovered that R68 & Q1 get super hot but Q4 & R66 stay cool, and the rail voltage drops from -44.5v to -38v over D9 zener, but doesnt drop at all over D8 (44.5v). I measured all the resistors conderned, they all check out. The preamp rails also aren't 100% either, 15v/-16.55v, but I havent replaced them yet.
I've read Enzo's posts on the BA115, and checked as far as I could, but no luck.
Why is the darn Q1 driver getting so hot that you cant touch it?
4732d1236851325-777sch_v3.pdf4731d1236851305-457sch_0.pdf
