this amp has new electrolytics and a rebuilt bias section..
when i got the amp it blew an ht fuse, i was using some low draw el34s biased around 25 ma..
i found a faulty 12ax7,replaced it, tested everything else again in my b&k 600 and loaded it back with tubes and a 1/2 amp fuse..
with my hoffman bias meter installed, the amp fired up fine, i let it idle checking both tubes turning the amp on&off,it idled around 25 ma per tube for a half hour at least..
the trannys are cool,no weird noises the el34s warm to the touch..
at this point i plug in a guitar and immediately i see smoke from one el34 socket..
at first i suspect a screen resistor and then notice a slight melted sopt between pins 2 & 3,the sockets do show signs of being hot btw but were like this before this problem..
any idea what i should check next? the screen resistors are 1k-5 watt..
did the socket have some carbon that caused the arce possibly? jcs
