Very low output. Swapped tubes, no difference. Cleaned FX loop jacks, jumpered them, too...no difference. Tried all the speaker jacks and impedence settings...no change. Effects send into another amp shows me the preamp is working normally. Guitar plugged into effects return = low/no output
All voltages present and correct on pins 3/4/5 of the power tubes, and on pins 1/6 of the 12AX7s.
Items of interest:
!R21 (100R) on the output jack PCB is a little scorched.
!!R6 and R9 (1R) coming off the power tubes measure 70K ohms in circuit, and R9 is burned/cracked in a small place on the resistor body.
!!!!!!!!!DC voltage measurement on the bias pins are around 18 volts per side...these usually meter around 80-90mV...what's up with this?
Thanks for your help!
Main Schematic
Output Jack PCB Schematic
Items of interest:
Main Schematic
