add bias pot to 1988 Carvin X100B EL34
  • add bias pot to 1988 Carvin X100B EL34
    I have a 1988 Carvin X100B with original EL34s. I want to replace them with different models of EL34s to get a different sort of tone. I want to ensure the bias is correct but this particular model/year doesn't have a bias pot. Does anyone have the steps to install one? I can solder pretty cleanly but don't know the specific steps. I have biased an amp before ( but it has a bias pot).
    Thanks in advance.
    Sam
    Here is Carvins link for the schematic.
    Link:http://www.carvinservice.com/crg/sch...0Schematic.pdf
    The specifically state "select R127 for idle current of 100ma".
    I guess you could put a 100K pot in place of R127.
    Solder the wiper to one of the outside legs or the pot.
      add x100b bias pot
      thank you. I've seen that schematic before; The work doesn't sound to complicated as long as you do neat work. Amp's with a tech right now, if he can't do it, I'll give it a shot.
      Thanks again.
      Sam
        None of the x-amps had a bias adjust pot. I've added them to all of mine.
          add x100b bias pot
          thanks fellas;
          GTR_Tech since you've done this before, is there anything specific I need to watch out for? Also, do you have a recommendation as to tolerance and wattage?
          Sam
