I have an avt 100 which has served me well untill now
The original problem was the TDA7293 chip overheating and smoking , the fixing screw was loose , tightened screw, amp was working ok for a while although the tone of the amp was compromised
Then there was smoke coming from diodes d217 & d218 , turned amp off . turned amp back on again and fuse blew , and d217 & d218 where definitely burnt out , when removed they crumbled to bits , are these problems related, or are there two separate problems.
when tightening the screw on the tda7293 ,could this possibly
cause the ic to short out to the heatsink ?.( i should mention the circuit board was pretty dirty under the vent where d217 & d218 are located on the top of the amp and was cleaned up during the general maintenance i was caring out )
Geraint
Geraint
