I have a TKO 65 with the following symptoms:
•Sound is distorted, output lower than normal and “Comp” light on continuously when playing.
•+/-43VDC and +/-15VDC are all good (and very close in magnitude) with normal AC ripple (millivolts).
•Pre-Amp Out to a known good power amp and speaker work fine – all pots respond as they should (gain and tone controls).
•Injected a known good pre-amp signal at the PWR AMP IN jack with same symptoms as before.
•Removed U3 (DDT chip) with no improvement in sound.
My next step for trouble shooting will be to try one of the “known good” 4558 chips from the pre-amp as a replacement for U4 and then U5 to see if this repair can be solder free! Of course I run the risk of damaging what was a good 4558 in the process…
I found the attached schematic on here already and have started my own "layout" but the real one would help. I tried e-mailing Peavey at 'pvrepair@peavey.com' and got a delivery failure.
Any suggestions? THANKS in advance!
