I'm working on one of these and this time, unlike the past, I did research the forum for previous posts on this amp. The amp here has the 6 el34s and the 2 bias pots in parallel. I have a bias supply of -41v. The tubes a running very hot at 60ma. Not knowing much about this circuit I started increasing the value of the 10k resistor that splits the 2 bias pots and goes to ground. By doing this I was able to bring one side down to the 38ma but the other 3 tubes remained in the 60sma. Can any one here help me sort this out?
I read here about re-building the bias supply to increase the neg voltage. Is that the only option?
Or do I need to add a resistor of some value in parallel to the 100uf bias cap?
Thanks in advance,
pete
Thanks in advance,
pete
