I have a Crate GFX 212 I'm working on for someone with a just barely audible distorted output , the type of amp which I often just suggest someone ditch and pick up a new one as the repair may cost more than the value of the amp. but as we know at times people still want it repaired.
So for anyone having the schematic handy, I've replaced R51, 55 and 63 which were all burnt ( though tested good) along with Q11 that was blown off the board and D21 shorted. Since the amp wasn't blowing fuses I hoped the Output trannies still good.
Unfortunately the problem is still there and some major heat coming off the replaced parts. So I pulled the TIP 147 pair of outputs to check them, although not completely shorted B-E , there is a very low resistance less than 1ohm and they conduct both ways with diode tester.
Would it be likely to assume these two power transx'r are the problem? I don't have any in my parts at this second so an opinion is appreciated.
Thanks
Thanks
