Ok while I'm at it I'm working on a Peavey valve king 100w head with only a very small amount of volume when switched to the lead channel. The clean ch seems fine/loud so my first inclination was it may be a relay sticking but usually w/o testing them I can tap around on them and get to switch. The only problem I've found so far is in the heater/+14v rectifier section , I'm getting about 24v where there should be 14v. I can't seem to find anything wrong in this circuit yet though.
I'm hoping i'm looking too deep and hopefully this is a known problem with this amp to some of you veterans
