hi,
i built a weber PR clone kit, which sounds great but seems short on power when voltage is measured across an 8 ohm non-inductive heat-sinked resistor. i tested the resistor with two meters, and it is accurate at all operating temperatures. with JJ's and sino 6v6's, i see 9v, and 10v respectively at the distortion threshold on my scope. so this is 9vrms^2/8ohm = ~10 watts, and 10vrms^2/8ohm = ~12.5 watts, right? this is with about 9 watts (per tube) idle dissipation in each case; 27ma*340v. it seems like i should be seeing more power/voltage across the dummy load. i expected 15-20 watts, is this reasonable? is it a result of my kit's lower plate voltage than the ~425v in the original PR? this is my second build; yes i'm a newb. please advise.
