Hi, new here and hoping for a little guidance.
I'm not new to electrical work, worked as a commercial/residential electrician, but no formal electronics training.
I found this Haze 40 schematic here on this forum http://music-electronics-forum.com/t16936/, and I've done some reading and research.
-It looks to me like I would check bias values at Con3, between pins 1 & 2 and between 2 & 3.
-The values I'm getting (DCA scale, 200u setting on the dial) are 26.9, and 43.8, respectively.
-If I'm not completely wrong, then I would adjust VR1 and VR2 to get the 39mv value for each (the 39mv is on the schematic at Con3.
Please, some one tell me if I've got this all wrong.
It seems logical that they'd be quite different, as the amp came from the factory with two completely different umatched EL24's in it... TAD "1" and TAD "2" on the labels and they're actually different heights...
Help would be greatly appreciated!
Thanks,
Les
Reason for this post: I recently had an output tube fail in my 1 year old Mashall Haze 40 Watt Combo, it's funny, if turned on either end, the amp sounded fine; but if operated int the normal position it squealed, crackled, thumped, and generally wouldn't work-if you tapped the amp case, it would freak out.
I got a new pair on Groove Tube EL34 Ms, and installed them and the amp works fine.
I need to set bias on the new tubes and I've never done this before.I got a new pair on Groove Tube EL34 Ms, and installed them and the amp works fine.
Thanks,
Les
