Hello, I am new here - thank you for taking the time to read my question.
I have what i believe is an early 80's JC120. 2EXT speakers, LINE out, 3Footswich, 2MAIN in, Toggle brights, Toggle Chorus/Vib.
I am having a problem where when the effects are engaged (Vib/Chrous) the output on that channel is very low and distorted.
Things to point out: I have verified each power amp is in proper working condition. Also, the signal does seem to get processed through the effect path when circuit is engaged.
To describe better, volume output is normal out of both speakers when effect is off. When it is engaged, left speaker volume stays the same and right speaker level drops significantly. While engaged, I can unplug the left speaker to listen only to the effect channel through right speaker. Output comes out very low and distorted, however each effect is discernible.
Neither of the three schematics circulating around match my amp boards. Roland has not been able to help locating correct schematic. It has the MN3004 chip (IC2) with a white trim pot located directly above that (VR9). There are only 3 other ICs on this board are MC140138, MC140118, and 4558JRC. There are 4 D736A output transistors. Also this version has the Chorus adjust pot on the back of chassis.
If anyone has any ideas or suggestions on what to look for, I would be very grateful for the help.
Thank You
Thank You
