Another amp problem! 3 weeks into a 10 week tour and this is the second amp to fail. I don't have much equipment: just a multimeter, a selection of components and soldering tools.
The amp is a Fender Pro Tube Twin and it produces a strange kind of distortion; it is most audible at low volumes - you brush the strings and it kind of fuzzes and cuts in and out - it almost sounds like a ring modulator as there's low ghost notes. When you strum hard it distorts: sounds alright but the overall volume of the amp seems reduced.
Using the Power Amp In jack, the amp works fine and free of distortion. Using the FX loop return jack still produces the distortion; so I'm assuming the problem is between the FX loop and the power amp in jack.
The schematic is here: http://support.fender.com/schematics...Amp_SchE45.pdf
I am going to check for leaky coupling caps and that the cathodes have the correct bias; other than that I'm stumped - any ideas? Is that transistor arrangement a power on mute for the preamp? Could that be at fault?
Any help or suggestions are much appreciated as always!
