I'm spinning off this topic from another thread because I didn't want to hijack the original thread. I've copied a post by Rob and reposted it here under the title of a new thread because I think the topic would be helpful to everyone if it had its own thread. Hopefully Rob won't mind.
Rob, I wanted to ask about your use of a variac and a limiting resistor. Are you using both of them at the same time, or are you using one or the other?
My approach to reforming caps uses one of two methods: a) removing all of the tubes, plugging an SS rectifier into the amp, and slowly bringing the amp up to voltage in 5% increments over the period of a day, or b) interposing a limiting resistor between the rectifier and the first filter cap (to limit the rate of current flow into the caps), and leaving the supply mains at 100% and waiting for the voltage difference across the resistor to level off. I don't use both methods at the same time.
In your experience, am I doing something wrong here? That is to say, would I be better off by using the limiting resistor to limit the "shock" that's applied to the caps every time that I give the variac a slight nudge? I have to admit, froma theoretical standpoint, using a smaller value limiting resistor and gradual steps on the variac might be better theoretically than using a larger value limiting resistor and no variac. I guess this all might depend upon the choice of the resistor.
At any rate, using the methods I described earlier I've successfully reformed caps on amps that I have been sitting in a dusty boiler room for 25-30 years. I've tested them for performance on a scope, and I've been quite amazed that the old caps appear 100% functional without leakage or abnormal resistance. Even the really cheap caps that were used in some of the "lesser" amps have provided surprisingly good results.
I have to admit, I am amazed that the old caps can be brought back to life this way and still operate in spec.
I understand that there are people in both camps about old filter caps -- there are some who are adamant that they should all be replaced in unison, and there are other people who are adamant that original caps should be retained in tweed amps whenever possible. I'd like to sidestep the controverial issue about what "should" be done for the amp, and focus on what some of the best techniques are for salvaging the original used/NOS caps, as this is what I'm most interested in for the "museum" part of my gear collection.
Many thanks!
Bob
Originally posted by Rob Mercure
View Post
Many thanks!
Bob
