I got a problem with my amp. It's not a known brand, because it's from an old Argentinian maker. It’s a very very simple amp: SS rectifier, a 12AX7 in the pre-amp, a 12AX7 in the phase inverter and two EL84 in a push-pull output stage.
The problem is in the power transformer
I wanted to install a stand by switch. So I used the old power switch in the front as the new standby switch and I drilled a hole in the back of the chassis and I installed what it is now the power switch. I also put the whole power supply circuit with the filter caps and the rectifier diodes in a board and took of some resistors from the circuit. What I got now is in red. The resistors I took off are in light blue.
The thing is that when I turned it on, it all worked just fine, no issues. The stand by switch also worked. But what was strange (at least to me) is that when I hit the strings too hard in the guitar, now the amp got mute. No more sound coming out of the speaker. A few days later the amp didn't work anymore. The notes are at low volume and like dirty distorted. This is because only 87 VDC, more or less, are getting to the plates of the power tubes and a little less, like 70VDC to the pre-amp and PI tubes. The power transformer is motor boating (it also makes the whole chassis to vibrate) and gets very hot after a minute or two. It’s not a very strong vibration but certainly it's stronger than before.
No matter if I open the standby switch or even disconnect all the tubes, still gets hot. I supposed the primary winding was shorted, so I disconnected the secondary winding, took a measure and I got almost 600VAC between the two leads of the secondary. Don't know the PT specs but I guess it's 300-0-300 so I guess the measure is correct.
With the secondary winding disconnected the PT doesn't gets hot nor vibrates.
I took also a measure at the 6.3V winding. With the secondary connected it drops down to 5.7VAC. With the secondary disconnected it goes up to 7.1VAC
And I also took a measure to the current. Seems like the poor tranny is drawing about 0.4A! I think i got the answer to the vibration
One of the rectifier diodes was dead because I took it out from the pcb, I measured it and I got 5.5k ohms between anode and cathode and vice versa! I replaced it, turn the amp on and the new diode is now dead too. 10k between anode and cathode and vice versa.
As I am a very newbie, first of all, can anyone explain to me how the he-- the original power supply circuit was rectifying the ac current with those 1Mohm resistors in parallel with the diodes!?
Second, any idea why my amp is dying? Or dead?
Regards
PS: The amp was doing normally before I mess it up. Moreover: I took off those 1Mohm resistors like 5 months ago and the amp was working without them.
Regards
