I'm working on an a 1968 Ampeg Portaflex SB-12.
When I plug it in, the indicator lights come on dim indicating a short somewhere which blows the fuse when I turn the amp on.
Pulled all tubes... problem remains.
Checked all filter caps... all have been replaced and even after disconnecting them... problem remains.
Checked the only solid state diode in the amp and it's good. All resistors good.
Disconnected all secondaries on PT. Does not blow fuse. Only when I replace the 370 volt center tap wire the indicator lights come back on dim and fuse blows.
When I check the ohms from the two red 370 volt secondaries to one of the primaries, one reads 3.40 ohms and the other reads 95 ohms. I'm starting to think the PT is bad but just want to be sure before I inform the owner. Funny that it don't blow any fuses when the secondary center tap is disconnected.
Any suggestions?
thanks in advance
Any suggestions?
thanks in advance
