I have an early silverface Pro Reverb. I had the bias circuit changed to bias adjust from the stock bias balance. I also had filter caps, coupling caps and the bias cap replaced. Otherwise it's stock.
Recently the amp has lost most of its punch and clean headroom. I replaced the power tubes with some that I knew were OK. I measured bias on the new tubes using a cathode current bias probe: They started out around 22 ma, gradually climbing to 28 after 1 hour. Then I played a little and the bias current jumped up to 35 ma and seemed to stay there, even with the amp idling. I tried to raise the idle current, but ran out of room on the bias pot.
Questions: Is the gradually rising bias current normal? If I wanted to increase the bias current, I "assume" I could replace the fixed resistor soldered to the bias pot with a higher value, increasing the resistance to ground. Is that the right way to fix this problem?
I basically need lots of clean headroom and can get my drive from pedals. I'm just looking to get that big, meaty tone back.
I've ordered some new tubes and will check the amp after a few hours of burn-in to see if they help. I've also ordered another rectifier tube just to have on hand.
More questions: The amp has a bunch of big, ugly brownish-orange caps that didn't get changed. Do these contribute to tone? Do they need to be changed? If so, what would I use to replace them? Finally, the preamp is a mix of 7025's and 12AX7's. Are there any specific recommendations for replacing these?
