I was getting ready to throw a basic billmod in a friends Ive done 3 before.
1) I was checking out the amp, and I'm getting 250 volt on pin 7 and 320 volts on pin 7 of the other el84. Reads 2.0 volts P1 to P2, and 3.5 P2 to P3. Swapped new tubes same, swapped phase inverter tube, same.
2) Pulled phase inverter, reads 3.5 volts P1 to P2, and 3.5 volts P2 to P3, replace phase inverter now reads 2.0 volts P1 to P2, and 3.5 P2 to P3,
R47, R35, R36 to spec. Im not sure what to check next????? Im baffled, but i think its something in the Phase inverter circuit. Any ideas would be helpful! John T.
