Hello. I am currently working on rebuilding a vintage Kustom 300 PA. When I got it, it had a blown power fuse. Turned out one of the 2N3055 type transistors was blown.I replaced it and (I have tested all transistors in the power section) I brought it up slow on the variac and with my current limiter I could see there was a short still somewhere in the circuit. Well I disconnected the power to the power amp and was getting normal readings from the power transformer and filter caps, so that is good. After checking every transistor on the power board through and through by using my diode setting on the meter, they all were reading fine. There are portions on the power board that appear to have been repaired with scorch marks and the whole bit but those components were replaced by a tech at some point and they read fine on the meter as well. I checked for dc on the output and I am getting immediate dc reading that are climbing to 15 volts dc at half ac power from variac.
I went ahead and replaced two (there are 3) of the NPN 40409 drivers on the power board but I am still getting DC on the output, there are 3 of the 40410 too.DC readings same as before. Any ideas where to start? Any help would be appreciated. Thanks!
