Carvin Legacy 100 head arcing issue
  • #31
    is it popping again or is that still gone, now just hiss?
    • #32
      The popping is not as loud or frequent as it was. The best way I can describe the noise is if you put a mic on a carpet and slowly pulled it around by the cable until you get to some stairs and then you start pulling the mic faster until you yank it down a set of stairs
      Helping musicians optimize their sound.
      • #33
        I decided to re-measure all the resistors in the cathode follower circuit. They all check out within tolerance. For giggles I swapped out R29, the 1 watt 47K resistor and sure enough that was the culprit. Thanks again Lowell for helping narrow down the correct stage.
        • #34
          That's awesome! So the popps and other noises are gone? Good job.
          • #35
            Yes in deed. The amp is very quiet now.
