I removed both transformers to compare out of circuit and they appeared to have equal resistances between windings. Cleaned the board top and bottom with sand paper and files. Raised the value of the two 2.7rs to 15ohms you, R.G. suggested in your first post, and that did it., the sound cleared up, the notch in the wave is gone. I didn't add the 10K in parallel w/ the 820s, tried it but didn't notice any changes so left it out. Hope that's doesn't come back at me.
Also found another bad connection on the other power amp board where a pigtail fuse was mounted which affected that channel.
Thanks for the help, much appreciated.
pete
pete
