I am working on an old Ampeg ET-2 That is pulling between 45 and 50 mA on each 6V6. Plate voltage is around 410v. The schematic does not list voltages, but I seem to recall a lot of older Ampeg and Fenders running high plate voltages with 6V6's. I also recall quite a few of these old cathode biased amps running over 100% dissipation without issue, but if my math is correct 18-20watts seems a bit excessive for a 6V6. While the tubes are not quite red plateing, it is apparent that they are running very hot. Since I cannot find the voltages this guy is supposed to be running at, I can't decide if I should try to lower the current by making the 250ohm cathode resistor larger, or if I should try to get the plate voltage lower, say around 360v or so (for some reason I seem to remember some old 6V6 ampegs running around 360v on the plates. Could be wrong!).
It has sovtek 5y3's, and was running EH 6V6's, but I tried a bunch of different 6V6's with roughly the same results...I guess I could try changing the rectifier to drop a bit of plate voltage as well....
Any suggestions?
Any suggestions?
