Hi there, I was wondering if I could get some help with my Peavey?
First some background. The amp was due to be thrown in a skip. It had had a foot through the grill and speaker. Pots were snapped off, the tolex was moldy and the metal work rusty. I've stripped the whole thing and cleaned & polished it up. Replaced the pots, fitted a new speaker and reverb tank. I inspected the PCB and noticed a burned out CR6 diode so replaced that. Also sprayed electrolube into the tube sockets.
So it's now been fired up and I have sound (and sounds good). However the power tubes start glowing very red very quickly so I shut it straight off. I noticed tubes 1 & 4 red plate (?) quickest. So I swapped them with 3 & 4 and they continue to redden quickest in the new position. However all tubes glow very red.
Can anybody advise why this is? I guess they are drawing rather too much current for some reason.
Note, whilst the pre-amp tubes are new, the power tubes are some old ones of dubious history. I intend to replace them at the end of the month, but am worried of replacing while the old ones look like they will burn out.
Thanks in advance for any advice you can give.
