Hi folks,
I have a Marshall AVT 150 which quit on me when I turned it on to soundcheck before our last gig. By luck I packed my effects pedal and managed to DI it. I had been running the amp in the morning that day so I know it was working as recently as 7 hours earlier.
It was raining heavily (well it was Glasgow) on the way into the venue and I was worried some water might have got in the vent at the top of the amp but this might be nonsense as I had it covered.
I've read through the posts and answers here but I'm kinda stuck with some of the terminology as I have no education in electronics and have only stumbled through repairs in a DIY basis for years.
The amp powers up, i.e. the power switch lights up and the fans are running. Therefore the fuse on the main board is good and power is flowing through at least part of the amp.
There is no sound from the speaker, no sound from the headphone socket when plugged in and no sound from the other speaker socket at the back.
The valve doesn't light up (I think it should glow?) and my mate gave me a replacement to try in case it was this but still no luck.
I've read that the faults might be some resistors (used as fuses), the TDA7293 chips or the mute circuit being shorted. The resistors I checked seem ok (tested with a voltmeter and showing resistance) but the chips and the mute cicruit I have absolutely no idea how to test.
I was going to order new chips and replace them but I've read stuff about using a variac (no idea what that is), something about releaseing teh voltage from some capcitors (not sure how to do that) etc to ensure I don't blow the new chips.
So .... short version is: can anyone give me an idiot's guide to what to do in order to safely replace the chips?
Cheers,
alan
Cheers,
alan
