Hi. i got a Bugera 333xl-212 combo. it doesnt count more than 30 hours of play and haven't turn volumes above 3-5 yet...and its out of waranty
issue a): yesterday at the rehearsal I've notice a small hum on clean channel while i was playing with no effects ( i only use clean channel as i get my sounds from pedals). hum gets stronger when i turn master volume or clean channel volume up...what should i start checking?
issue b):i also notice a whistle noise on Crunch and lead channel only, which gets louder only by turning volumes up ( not gain) also crunch and lead channel has Hum...\
the whistle goes away when i use my pedals or clean channel ( hum on clean channel remains)...at a gig last week i didn't had any whistle problem only hum ( which isn't annoying and its hard to hear it when master volume is under 6-7 or if its not quiet and not traceable or bothering while playing but it should be quite i think). the whistle is really annoying since i start to like a lot the crunch channel of this amp and its really important to fix it..i will appreciate any help you can give me
yesterday also the Standby led in the front panel went dead...which i guess it should be easy to be replaced by me...
i have some basic electronic knowledge so i think i will proceed to the repair my self if someone can guide me
again i will appreciate any help given and i thank you in advance
