bad preamp tube creating open ground?
  • bad preamp tube creating open ground?
    I built a 5f4 clone three years ago and up until about three months ago, it had been trouble-free.
    Three months ago, it developed an open ground, and the only sound out of it, was 60-hertz, as if a cord was plugged into the input and not plugged into a guitar. Didn't matter if it was attached to ANYTHING, it was LOUD 60-hertz.
    I did everything I could think of to do, swapped tubes (which at the time didn't seem to help but I swapped them all at once - still it should have fixed it) and it didn't. I cleaned the little switch legs on the shorting part of the jacks and eventually replaced the input jacks. No dice.
    Finally I admitted I was in over my head, and took the amp to a tech. He diddled with the input jacks and it was ok. For a week. Then it was back.
    I replaced the jacks. No dice. I sent the amp to another tech who cleaned up some of my soldering and when I got it back, I got a nice, quiet amp - for about a minute. Then it was back to the usual only this time the volume controls had no effect on lowering the volume.
    I called a third tech and he said I could bring it in but I should pull the phase inverter and see if it stopped. (it did). I then pulled v2 (by itself) and it also stopped. So I dug out some different tubes (mostly ANOS Phillips AX7s) and put them in.
    The amp was quiet.
    THe 2 AX7s I pulled were the long-plate JJS. Is it possible for those tubes to develop an open ground? I know some of you don't like JJs, and I'm not here to debate the merits, I just want to know if a preamp tube, JJ or not, can develop an internal open ground? Because while the problem appears to be fixed for now, I want to be sure the fix is permanent and not just a band aid.
    Thanks in advance.
    Some JJECC83s seem to have had slightly thinner pins, leading to intermittance, do you think that the issue is an internal one, or simply intermittant contact between pin & socket?
    Turn the amp up full, all controls fully CW, and gently rock the preamp tubes and see if you get any unwanted noise.
    I have only seen a handful wth this problem, the vast majority are OK. But if the tubes in question are noisy, then replace them.
      I've had some noisy tubes from both Sovtek and JJ. But I would think it a really rare thing to have several in a row. I think it's like MWJB said, an intermittant pin connection. Has anyone tried cleaning and retensioning the tube sockets?
